Author Topic: another water leak in the engine.  (Read 1974 times)
Blue MK2
« on: 11 December 2003, 20:05 »
Ive replaced the 'O' ring today and i can still see water leaking.
Its that part where the water pipes go into the head with the blue connector on top of it. :-\
Also, does the blue connector connect to the blue socket and the black connector to the black socket? Mine is the opposite.
Any ideas peeps?
Offline dubslug
Re:another water leak in the engine.
« Reply #1 on: 11 December 2003, 20:09 »
if its leaking through the plastic bit it could be warped, same happened on mine but mines only a driver so may be different, just a thought though
1992 pearl grey 8v
Offline mk1
« Reply #2 on: 11 December 2003, 20:46 »
Housing will have small cracks in it around the bolt holes :( . New housing required.
Blue to blue, black to black usualy. Does it run ok and the guages work ok?, if so leave it alone ;).
Steve.
Blue MK2
« Reply #3 on: 11 December 2003, 20:55 »
Cheers.
i put blue to blue then black to black and the car didnt sound healthy so i switched it back to the original.
Ill have another look at the leaky part 2moro for cracks.
How much would this part set me back?
Offline mk1
« Reply #4 on: 11 December 2003, 21:12 »
?14 + vat springs to mind, may be wrong.
Steve.
