The garage
proportional valve again!
Topic: proportional valve again! (Read 1612 times)
dibdub
11 December 2003, 19:39 »
still having problems with it.need more help if anyone can.apparantly the valve is leaking?does it need replacing?if so how much we looking at?easy to do? also is there any common feul leakage problems on the mk2 16v?thanks for any help in advance
mk1
2ltr16v turbo (now with programmable EFI)
Re:proportional valve again!
11 December 2003, 20:50 »
Leaking valve requires replacing
. Don't know how much. Fuel leak, check the metal pipes along the floor while the engine is running. Common for corrosion where they clip to the floor.
Steve.
http://www.geocities.com/mk1turbo16v/golf_turbo.html
The garage
