Author Topic: How do I change key in the fob?  (Read 1902 times)
Offline dantis
« on: 02 June 2006, 19:36 »
Hi everyone, I have a MK4 Golf and the rectangle keyfob was really tatty, sellotape was holding it together!  It worked fine, so I bought a complete fob off eBay which is in really good condition, now I need to know how I can get the keys out of the fobs so that I can change them over, I can't simply split the fob in half and swap them over because it is the top half of my fob that is broken.
Any advice would be appreciated.
Thanks.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: How do I change key in the fob?
« Reply #1 on: 02 June 2006, 20:00 »
I'm not 100% up on this, but I 'think' you have to buy a BLANK fob of ebay, (is that what you've got?), & get the key cut at your local key cutter (if they'll do it, that is).  Then you have to get the immobiliser programmed by somebody with 'VagCom'.
You can program the remote locking yourself, though.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline dantis
« Reply #2 on: 02 June 2006, 20:10 »
No, I have bought a second hand fob complete and I just need to swap the keys over.
« Reply #3 on: 02 June 2006, 20:55 »
I may be wrong, but I don't think you can easily replace just the key blade. :undecided:
Offline Phil_M
« Reply #4 on: 02 June 2006, 21:20 »
Open the switchblade key to the halfway position, look closely at the pivot point and you should see a small hole with a pin inside of it. Your goal is to get that pin out. Once the pin is out, the blade should slide out.
HTH
Phil
GOLF 1.9T AGU TD05H 18G
http://smg.photobucket.com/albums/v218/pipmann30/GOLF%20GTI%20%20TURBO/?albumview=slideshow
Front wheel drive monster 0-60mph in under 5sec 0-100mph in 10sec
Offline dantis
« Reply #5 on: 03 June 2006, 11:23 »
OK, so I managed to get the key blade out and swap it over, great, but when I tried to start the car it just kept stalling and an icon of a key appeared on the dash, so obviously there must be some sort of transponder in the top half of the fob which operates the immobilizer, I swapped them back and it was fine, but now I am back where I started  :undecided:
Any ideas guys?
Offline Phil_M
« Reply #6 on: 03 June 2006, 13:41 »
You need to take the car and the new fob to your vw dealers, and they will programme it for a small fortune, but make sure it is the right frequency first.
Offline ub7rm
« Reply #7 on: 03 June 2006, 19:09 »
If you butcher the 'forward' part of your old key, I suspect that you will find a small black chip in there, I think you should be able to swap this with its equivelent number in your new key.  The black chip is the imobilser transponder and if swapped over should mean that you don't have go near the dealer.  The bugger is is that you will have to take the forward part of your new key apart and I dont know how easy it is to put back together  :undecided:
May be talking sh!te but I know that this trick works for vauxhalls.  Those keys are a lot easier to take apart though.  Worth taking the old key apart to see if the chip is easy to get at and what reassembly will be like.  HTH.
Ron
2020 BMW 128ti
2017 Golf GTD Estate
