Author Topic: Water pump  (Read 954 times)
mix
Water pump
« on: 02 June 2006, 17:39 »
Mine is leaking from around the join were it splits in two....is there a gasket i can replace or have i got to replace the whole pump??
Re: Water pump
« Reply #1 on: 02 June 2006, 22:08 »
There is a gasket, but if you're going to all the trouble of replacing it you might as well stick a new one on there!
Offline Rain
  • forum irregular
Re: Water pump
« Reply #2 on: 02 June 2006, 23:53 »
do the belts and the cam belt tensioner too while your at it :D
Offline AudiA8Quattro
Re: Water pump
« Reply #3 on: 03 June 2006, 00:12 »
You can access the cam belt tensioner with all that still on, so just do the pump  :laugh:
Offline Agreeable Slick
  • Unit
Re: Water pump
« Reply #4 on: 03 June 2006, 01:26 »
It's going to be easier to do the whole lot, pump is only about 20 odd from gsf, and the belts a couple of quid each.
Either your brother or me can give you a hand.  :smiley:
mix
Re: Water pump
« Reply #5 on: 03 June 2006, 11:47 »
Cheers people, it's nothing to bad at the moment, gonna try and get it done though....
Re: Water pump
« Reply #6 on: 03 June 2006, 23:28 »
Just make sure the mating faces are shiney clean when you fit the new pump...
