Author Topic: Golf G60 Limited slip diff ???  (Read 3168 times)
Offline don52b
« on: 01 June 2006, 22:11 »
Hi guys can anyone help me on this. Did golf g60's come with a factory option of a limited slip diff ? If so does anyone know the option code that would confirm this ? Cheers
Offline Agreeable Slick
  • Unit
Re: Golf G60 Limited slip diff ???
« Reply #1 on: 01 June 2006, 22:12 »
I didn't think any of the golfs did apart from the Synchros, Rallyes and Ltds.
Offline don52b
« Reply #2 on: 01 June 2006, 22:16 »
How would i tell if mine has one ? Wheel rotation when jacked up ...?
  • Unit
« Reply #3 on: 01 June 2006, 22:17 »
pretty much.
Offline don52b
« Reply #4 on: 01 June 2006, 22:23 »
Sorry slick - just to confirm - if i jacked the right front end up and the wheel would turn either way like the brakes were on = lsd ???
  • Unit
« Reply #5 on: 01 June 2006, 22:28 »
Jack the entire front end up and then if you turn one of the wheels then the other should turn with it. If not then they are not linked by a LSD. I would presume yours will not have this at all.
Offline AudiA8Quattro
« Reply #6 on: 01 June 2006, 22:34 »
I didn't think any golfs were fitted with an LSD from factory??
mix
« Reply #7 on: 01 June 2006, 22:39 »
mainly because LSD would f**k you up if you took it when driving :laugh:
Offline don52b
« Reply #8 on: 01 June 2006, 22:42 »
Funny man  :grin: . Will check tomorrow. Also and i know this is an old question but is there a comprehansive online list of all factory options and codes and what they mean. Eg - the boot sticker ??
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 02 June 2006, 00:35 »
as far as i know lsd wasnt, and still isnt a factory option on any golfs, including the 4wd/syncros.
