Author Topic: mk3 1.6 cutting out  (Read 898 times)
Offline bustersballs
mk3 1.6 cutting out
« on: 01 June 2006, 19:48 »
mk3 1.6 abu engine single point injection, cuts out randomly! will start again if left for a few minutes ,checked for spark when its "dead" and a good healthy spark is present, disconnected the feed pipe to injector unit and there doesn't seem to be much pressure there. is the pump in the tank dying?
Offline monkeyalan
Re: mk3 1.6 cutting out
« Reply #1 on: 04 June 2006, 11:44 »
gti's have a problem with the fuel pump relay, maybe it's the same with the 1.6? only about £10 so worth a try?
