Author Topic: Lowering on standard Shox  (Read 2124 times)
Offline BigDaveC
« on: 31 May 2006, 16:44 »
Sorry this has probably been asked 1000's of times before !!
Can you lower the suspension on standard shox successfully ???? Eibach say you can use their springs to lower 30mm ok ?? I can't really afford the short dampers to go with them.
Offline BigDaveC
Re: Lowering on standard Shox
« Reply #1 on: 31 May 2006, 17:52 »
Thoughts on these for a cheap 'upgrade' to standard suspension ? (money is tight + fitting!)
http://cgi.ebay.co.uk/SUPERSPORT-Suspension-Cup-Kit-60-40-VW-Golf-3-Jetta-MK3_W0QQitemZ8070333038QQcategoryZ40192QQrdZ1QQcmdZViewItem
Offline GolfGL
« Reply #2 on: 31 May 2006, 19:01 »
Have you thought about doing the fitting your self. The only prob is the camber adjustment and the top nut on the front, so get it wizzed off prior to fitting by a garage. Personally id get it all done in one go because more than likely the standard dampers are fooked already and after you have just the springs done you will want to do the dampers so will save you time and money in the long run. A cheap combo would be boge turbo dampers(gsf) and h&r springs but if you want more comfort the eibachs are better
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline BigDaveC
« Reply #3 on: 01 June 2006, 21:19 »
Cheers for the info mate. There's no way i can do it myself. No time or space ! Your probably right about the job lot. !
Offline monkeyalan
« Reply #4 on: 05 June 2006, 20:45 »
i've had eibachs on standard shocks for well over a year and 2 mots with no problems at all. nice ride quality too.  :wink:
Offline BigDaveC
« Reply #5 on: 05 June 2006, 20:49 »
cheers for the info mate. I've looked at my dampers and they look a bit rough and tatty, and are probably knackered tbh. I've bought the above kit, so we'll see how that goes !
