Author Topic: Mk3 Anniversary  (Read 1026 times)
Offline chris_Mk3Annivers
Mk3 Anniversary
« on: 30 May 2006, 12:56 »
Hi All
Just joined as ive repaced my wallet emptying Seat Leon Cupra R with a more money friendly Anniversary.
This is my first golf after a Scirocco GT2, Corrado G60, Polo Gti and the Leon.
Im real impressed apart from the little fault of it not 'breathing' properly on idle and between 3 and 4k revs on acceleration (not all the time, intermitant problem)..
Had a look through the forum and seems to back up a fault diagnosis by my VW garage of a Faulty Air Mass Meter..
Is this a common fault and is the heat shield rattling a common fault too...????
Offline Overseer
Re: Mk3 Anniversary
« Reply #1 on: 30 May 2006, 14:03 »
cat heat sheild rattles are common.. an meant to be easy fix with a large jubilee clip..
not sure about the other..
is yours an 8v or 16v anniv?
Re: Mk3 Anniversary
« Reply #2 on: 31 May 2006, 09:21 »
16v Anniversary  :cool:
I think after the Mk1 the Mk3 is the best looking golf, although the new one looks hot  :nerd:
« Last Edit: 31 May 2006, 09:23 by chris_Mk3Annivers »
Offline Overseer
Re: Mk3 Anniversary
« Reply #3 on: 31 May 2006, 12:46 »
ok..
for the breathing thing.. i'd
1) check all the vacuum hoses for leaks + good connections
2) check that no 'breathing mods' have been made..
3) check the brake servo vacuum feed for leaks too (should have been covered by 1 :P buts its a bit seperate..)
4) clean out the ISV.. dead easy to get at on a valver.
i've had all the above before.. so it could be any of them..
