Author Topic: Airbag connections  (Read 1170 times)
Offline tigertimmy
Airbag connections
« on: 30 May 2006, 11:29 »
I purchased a new set of seats which I fitted this weekend.
My bad call here, I forgot to check that the airbag connectors for the 2 front seats would fit in to the car.
The plastic bit at the end of the wire on the chairs does not connect to the plastic bit that comes from the car. :undecided:
I have the old seats so I could take the plastic connectors off those.
Has anybody had a problem like this before?
Is there a part I could purchase to change one of the ends?
Any help would be great,
Cheers,
Tim
Offline nadlad
  • Building Surveyor MRICS
Re: Airbag connections
« Reply #1 on: 30 May 2006, 12:12 »
just had that prob basically seats prior to 2001 have a diff connection if ure car is newer than 2001 so therfore u can splice ure old ones off and solder ure new ones on after d/c battery for 30mins
all ure answers are here
http://www.golfgtiforum.co.uk/index.php?topic=39653.0
<<<Big Build Thread>>>
