Author Topic: Spotlights!  (Read 925 times)
Offline Tornado
Spotlights!
« on: 29 May 2006, 17:22 »
Hi there
Just a quickie!
How do you remove the spotlights from the grille?
2 of the connections are threaded so thy are easy enough.  however 3rd connection is a knarly looking thing. Do i remove the whole thing including the plastic clip or is ther another way?
Regards
Alan
Lower!
Offline pegasus
Re: Spotlights!
« Reply #1 on: 29 May 2006, 18:27 »
you have to turn the plastic clips through 90 deg to line up with the slots,
the spots should then push out from the back ;)
1.8 20VT GTI
Offline Tornado
Re: Spotlights!
« Reply #2 on: 29 May 2006, 19:27 »
Thanks Pegasus
I will give it a bash
Alan
The nylon clips are held in place by 2 small lugs on the metal frame which prevent easy rotation of the nylon part.  Should I just force it and buy new clips or can they be teased over the lugs without breaking?
Ta
Alan  :undecided:
« Last Edit: 29 May 2006, 19:54 by Tornado »
Lower!
Offline pegasus
Re: Spotlights!
« Reply #3 on: 29 May 2006, 20:13 »
Use a pair of pliers on the lugs (bit of wd40 too) and like you say "tease" them...
**EDIT** Make sure you turn the lugs anti clockwise ;)
« Last Edit: 29 May 2006, 20:28 by pegasus »
1.8 20VT GTI
