Author Topic: boot wont open and cant get key into the lock  (Read 10794 times)
Offline burna
« on: 26 May 2006, 19:42 »
my boot wont open, when i unlock the doors the boot stays locked, also i cant get a key into the bootlock either. any ideas how im going to 1. open the boot and 2. repair it?
cheers
see this....this......this is my BOOMSTICK!
Offline Rhyso
Re: boot wont open and cant get key into the lock
« Reply #1 on: 26 May 2006, 19:57 »
thats a trixy one for sure mate.
def sounds like you need a new boot lock.  my guess you'd need a specialist locksmith and or take it to the dealership to sort out but i'm guessing its going to be a little pricey  :cry:
you could probably try 'breaking in' yourself but you may end doing more damage  :sad:
wow.....not much help am i  :sad: sorry bud
Offline GolfGL
« Reply #2 on: 26 May 2006, 23:42 »
Have you tried some penetrating fluid to ease the lock as mine is rather stiff so ive had to keep it regularly greased. There is a boot release relay number 18(79/407) so thats top second to right and it also has a fuse f38 (15a) but its unlikely to be that as it opperates the fuel cap, and all central locking. Hope you get it sorted.
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #3 on: 27 May 2006, 11:19 »
Usually, you can 'dead-lock' the boot with the key so that it always stays locked even when you open the doors with the remote.
My first guess would be that your boot lock has seized in the 'dead-lock' position, which would explain why it remains locked when you open the doors).
It's definitely worth trying spraying a little WD40 or similar into the lock (with that straw attachment that comes with it), & also spray a little on the key blade.  My boot lock's a little sticky, come to think of it.  I have to push it right in, then give it a little wiggle before it will turn.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #4 on: 27 May 2006, 18:46 »
Can you not release the lock from inside the boot?
« Reply #5 on: 29 May 2006, 10:38 »
Never thought of that/needed to try??!! :laugh:
Will have to have a look, later. :wink:
Offline Red-I
  • MkIV 1.8T
« Reply #6 on: 29 May 2006, 13:25 »
Hi, I've just joined the forum too! Just acquired a 1.8T and loving it.
I hope I'm not stating the obvious (and shoot me down if I am lol), but you are aware that if you press the door open button on the drivers door controls it unlocks the boot aswell?
It's the same action you get when you double press the remote.
hope this helps, and if not let me just say hello to you all!  :smiley:
EDIT: re read your post and woops. I realise now you mean physically releasing the catch from within the boot. I had a quick look, are you liekly to be able to get the trim panel off the tail gati without opening the boot? You might be able to ping the mech if you can.
« Last Edit: 29 May 2006, 13:29 by Red-I »
Offline smitho
« Reply #7 on: 06 June 2006, 19:42 »
I had the same problem. i sprayed loads of WD40 in the lock.then force the key in.wiggling it from side to side.it soon fixed the problem. being carful not to damage the key.it had corroded inside the lock from water getting inside.
