Author Topic: fuel filter change on MK2 any tips  (Read 21880 times)
Offline Diluxe
« on: 09 December 2003, 13:48 »
Thinking of servicing the car this weekend, been reading someposts were peeps have changed the oil filter and the car refuses to start.
Any tips and words of advice as best to do this and things not to do, its a 88 16v filter rear of the car laft hand side
cheers
1997 16V
Blue MK2
Re:fuel filter change on MK2 any tips
« Reply #1 on: 09 December 2003, 17:16 »
u mean fuel filter? :P
Duno mate but i know this post will help me out also
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 09 December 2003, 22:51 »
errr, what's the question again?
do you want to know how to change the fuel filter?
Mk4 Golf 150PD
Blue MK2
« Reply #3 on: 10 December 2003, 10:11 »
the fuel filter Dizzy rascle.
Offline Diluxe
« Reply #4 on: 10 December 2003, 12:14 »
well my car broke down last night and refused to restart, left it 20 mins tried again and it started, been told by a few peeps at work aounds like i had some sort of blockage, as the engine was turning over just not sparking.............. so the sooner i change this filter the better.
what i dont want hapening is unplug thefilter and petrol comes shooting out all over the shop ::)
so any tips and do nots greatly appreciated
1997 16V
Offline richandhazel
« Reply #5 on: 10 December 2003, 12:19 »
Its fairly straightforward, do you have a Haynes manual as there is a write up in there?
Offline Diluxe
« Reply #6 on: 10 December 2003, 12:35 »
Yep got a haynes manual, all it says un plug the pipes stick new one on , is it really that simple ;D
do i need to fill the new filter with a bit of petrol 1st so the car doesnt struggle starting?
1997 16V
« Reply #7 on: 10 December 2003, 12:40 »
Yep it really is that simple.
I don't think there is any need to prime the filter as the pump should manage to get the fuel px back up fairly quickly (I've never done it anyway, I think you're more than likely going to end up with the fuel all over you).
I'll just double check the Bentley and see if that has anything to add. Back in a mo..........
« Reply #8 on: 10 December 2003, 13:03 »
Well I would look in my Bentley, only I can't get it to work >:( Worked last time I used it >:( Bloody PC's >:(
Offline Dizzie
« Reply #9 on: 10 December 2003, 13:09 »
1) jack her up*
2) undo the bracket holding the filter to the car
3) undo the pipes on both ends of the filter
4) get covered in fuel**
5) bolt the new one on
6) lower off jack
7) start up and check for leaks
*As always when working under the car support with axel stands
**not essential
« Last Edit: 10 December 2003, 13:10 by Dizzie »
Mk4 Golf 150PD
