Author Topic: 16v vacuum advance  (Read 2096 times)
Offline Manchester
16v vacuum advance
« on: 25 May 2006, 20:25 »
Hello,
Any VW guru's out there could help me with my vacuum circuit for KR engine?
Ideally if someone could draw me a diagram of what connects to what since currently nothing is connected at all :huh:.
Many thanks in advance,
Manchester
Re: 16v vacuum advance
« Reply #1 on: 25 May 2006, 23:16 »
Any good:
Offline Manchester
« Reply #2 on: 26 May 2006, 08:50 »
Thanks Rubjohnny,
It looks like you have a slightly different setup to me though :undecided:
I have no EGR or carbon canister system. My engine is a '90 UK model.
I do however have a vacuum inlet on my ECU which is controlling vaccuum advance.
I guess this needs to know vaccuum in the vicinity of the throttle body?
Dashboard conects to the MFA right?
I also have a vacuum conection at the overrun cuttoff valve and some kind of pressure diaphragm next to it. I cant tell if this is the same as the on/off valve and frequency valve on your diagram.
Thanks again,
Manchester
« Reply #3 on: 26 May 2006, 09:01 »
MFA is the dash yeah, you should actually have a diagram like this in your engine bay somewhere, usually on the bonnet or slam pannel (assuming your car originally was a 16v)
I've never actually owned a 16v myself so I can't really offer much more help!
Offline Manchester
« Reply #4 on: 26 May 2006, 09:22 »
Unfortunately i don't have the car that came with this engine..
Can anyone help me work out how my vacuum advance is meant to connect?
I'm hoping to make it to stoner park on the 4th, could be a good chance to check out some vacuum circuits  :nerd:
Cheers,
Manchester
« Reply #5 on: 26 May 2006, 09:39 »
I have another diagram from the haynes which seems to show a vacuum connection from the throttle body T's off to the vacuum advance and the Overrun cut-off & Diaphragm pressure valves:
Offline rowlers
  • I'm back - MK7 GTI
« Reply #6 on: 26 May 2006, 20:24 »
heres another one for you:
Offline Manchester
« Reply #7 on: 27 May 2006, 14:11 »
Thanks guys,
looks like good stuff, just got a load of vacuum hose so will have a go at connecting it up this weekend.
If the rain ever stops...
