Author Topic: What to look for - your advice please  (Read 1473 times)
Offline johndow
« on: 25 May 2006, 12:18 »
I would like to buy a MK2 GTI sometime this year (next few months), to store, and gradually do up (back to original).
The problem is, i am in Northern Ireland and GTIs are rare and expensive. I would happily go to the mainland to buy one if i saw the right car, but i don't want to buy a piece of crap.
If you were buying a car without seeing it in person, what questions would you ask, and what photos would you ask for?? (e.g. has it any rust, second gear crunch etc etc)
If i can produce a list of things to look out for, it may also benefit other members/ potential buyers.
p.s. i am not a mechanic, so keep it simple please.
JD
Offline Organisys
  • Old and Slow...
Re: What to look for - your advice please
« Reply #1 on: 25 May 2006, 12:29 »
Rust to body shell, and blowing oil / emmisions, everything else can be fixed really.
Offline knobby
« Reply #2 on: 25 May 2006, 16:30 »
nice clean interior i like to see.. Check the bolsters are still in good nick and not worn...
Old VW's never die...they just go faster!
Veedubgt18v
« Reply #3 on: 25 May 2006, 19:38 »
http://www.matey-matey.com/golf_buying_guide.shtml
have a read of this pretty much covers everything
Offline Gambit
« Reply #4 on: 26 May 2006, 15:58 »
that matey matey guide is a good job - but its easier to get somebody to actually walk you round a mk2 pointing what to look for.
here is the local NI board mate - http://www.clubgti.net - im in Belfast myself
Offline TIM20
« Reply #5 on: 26 May 2006, 18:58 »
Right im bored so i will list the things that are important
Body work wise:
rust in the following areas:
around the petrol cap
under the rear arches if the plastic covers are there
front wiper hole grommit
around the front screen
around the door locks if damaged by attempted breakins
in sunroof tray if possible
the battery tray under the bonnet
rust where the exhaust maifold exists to under the car (from heat etc)
rust around the drain holes on the lower section of the doors
rust around the tailgate near the lock and the wiper hole
General things
16v clocks not working correctly (MFA etc)
excessive wear on the drivers seat bolster
automatic clutch cables are crap and dont work correctly
high milage is common now but if looked after correctly they go on for ages
look for blue smoke (valve stem seals)
and the tappets can get noisey
also just look out for general acciednt damage
The main thing i would say is prepared to be disapointed a few times as there are a lot of sh!tters out there for every decent one
Tim
