Author Topic: no oil warning light  (Read 1115 times)
Offline bokken
« on: 24 May 2006, 15:36 »
Can anyone identify where the various oil warning sensors/senders are in the engine bay please as I don't have a warning light on ignition. Cheers
Re: no oil warning light
« Reply #1 on: 24 May 2006, 15:50 »
you have 2 senders, low & high pressure.  The low pressure sender is the black/brown one with a blue wire, high pressure is the white one with a yellow wire.  If the car is a 16v both are in the oil filter housing, if its an 8v then the low pressure is on the side of the head and the high pressure is on the filter housing.
Offline bokken
« Reply #2 on: 25 May 2006, 19:08 »
thanks - found them -  now I've just got to figure out why I'm not getting any warning light on switching on???
« Reply #3 on: 25 May 2006, 21:31 »
It may be a problem with the oil pressure warning circuit board, the 'L' shaped circuit attached to the back of the speedo.  A dodgy 'fix' for the oil pressure warning buzzer going off is to remove the board altogether :rolleyes:
Offline Rain
  • forum irregular
« Reply #4 on: 25 May 2006, 21:37 »
tried the led? just a thought.
Offline bokken
« Reply #5 on: 26 May 2006, 06:16 »
Thanks - next job is to replace instrument panel as rev counter and MFA don't work - this might do the job!! May thanks for suggestions
« Reply #6 on: 26 May 2006, 09:05 »
Try pullin gthe dash fuse for 30 seconds, this will normally fix a dodgy dash :)
