easiest way, is to undo the hex bolt holding the surround to the wheel, and the bolt at the bottom (take it completly out!!) holding the column to the UJ. Then the whole thing will slide up and out of the car. Next you need to drill a hole in a specific location so you can press in a clip, then the lock will pop out.
OR you could just swap the columns over completly
