Author Topic: Gearbox plug  (Read 790 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
Gearbox plug
« on: 23 May 2006, 13:14 »
What size and tool do i need to remove the gearbox oil plug?
Re: Gearbox plug
« Reply #1 on: 23 May 2006, 13:29 »
17mm if you mean the fill & drain plugs.  If you mean the big green one in the top to check the flywheel (its NOT a fill hole!!!) Then I think its 24mm or something like that.  Sorry if you didn't mean the green plug, but its a common mistake to make so thought I should check ;)
