Author Topic: spotlamp settings..  (Read 824 times)
Offline gti jim
  • return of the vac...
spotlamp settings..
« on: 23 May 2006, 11:08 »
i've replaced my inner spotlamps a couple of weeks ago and am fairly happy with the setting..  however was just wondering if anyone has got a picture (of the beam pattern) or anything of assistance to make sure i've got them set perfect.
advice as always appreciated  :smiley:
Offline JMallows
Re: spotlamp settings..
« Reply #1 on: 23 May 2006, 11:49 »
What i did with mine was park up against a wall, the put low beam on, and draw a line on the wall in chalk where the beam is. Then, put high beam on, and adjust until the spot is in the middle of the chalk line, or a bit below. Or, whereever you want the beam to point!
A clever person solves a problem. A wise person avoids it.
Offline gti jim
« Reply #2 on: 23 May 2006, 13:21 »
cheers jm, i had the beam of the spots sitting at the top of the headlamp line, was thinking they could have done with going a little higher  :wink:
