Author Topic: my Mk1 Gti Has a problem  (Read 1878 times)
Offline first timer
« on: 08 December 2003, 20:49 »
Hi,
I have recently become the proud owner of a Mk1 GTI on an 83 plate.
Its a wicked car apart from one small problem.............
The indicator led on the dashboard glows a little bit; and when I use the indicator stalk the LED goes bright but nothing happens. The hazards work ok and so does the parking lights, I have dried the fuse board out (incase it was damp) and changed the relay and the stalk and also changed all the fuses but still it no working. If any one can help I would be eternally grateful.
Blue MK2
Re:my Mk1 Gti Has a problem
« Reply #1 on: 08 December 2003, 20:52 »
have you inspected the back of the clock for damaged circuits?
Offline AdamB
  • The Perfect Storm
« Reply #2 on: 08 December 2003, 20:52 »
Check the back pf the instrument pod for electrical damage, it sounds like the earth to the indicator LED has gone. you may have to repair the earth on the printed circuit board on the back.
I don't own this anymore - I just can't be arsed to change the picture
Offline first timer
« Reply #3 on: 08 December 2003, 21:05 »
Thank you.
I will give it a go.
Its been more useful logging on to speak to you people than a whole week going to garages.
Offline mk1
« Reply #4 on: 08 December 2003, 21:12 »
Try another hazzard switch, def sounds like a switch fault.
Steve
