Author Topic: advice please  (Read 2384 times)
Offline pitchy
advice please
« on: 20 May 2006, 23:53 »
couple of things i need a bit of help with please lads ...
(1991 golf 2 driver 1.6)
whats the engine specs ? looks like single point inj ? any easy bolt on upgrades ?
tiny (solid ) brakes , can i upgrade to 16v with no problems ?
does the corrado front end bolt straight on ?
anybody got any big bumpers for sale ?
also have an annoying rattle front end , thought it was the grill , but ruled it out , any ideas ?
thanks for amy responce
2002 gti aum mods-cai / n75j / 007p / stg1 remap / rs4 reps .
things done in the last few months - new temp sensor / new gearbox oil / anni matts / painted interior trim / debadged /
things to do - refurb wheels-satin black / coilovers / paint headlights internals black / fit fmic / 3" turbo back / stg2 remap
Offline Agreeable Slick
  • Unit
Re: advice please
« Reply #1 on: 21 May 2006, 00:01 »
whats the engine specs ? looks like single point inj ? any easy bolt on upgrades ?  72BHP 92 lb/ft , single point IIRC, Not really.
tiny (solid ) brakes , can i upgrade to 16v with no problems ?  you will need to change the carriers, calipers, and tbh there isn't any point.
does the corrado front end bolt straight on ? No, and it won't do apart from a major front end rebuild, and would still look naff. [/b]
anybody got any big bumpers for sale ?  check the for sale section
also have an annoying rattle front end , thought it was the grill , but ruled it out , any ideas ?  exhaust heat shield on the bulk head
Offline pitchy
Re: advice please
« Reply #2 on: 21 May 2006, 00:12 »
surely 16v brakes will b better than the tiny things on it now ? i just got rid of my mk3 1L polo and by the looks of it they had the same brakes ?
is the heat shield a common problem , couldnt actually see 1 , will check tmora tho
thaks ne way pal
  • Unit
Re: advice please
« Reply #3 on: 21 May 2006, 00:14 »
It's only 72 bhp mate, the brakes are fitted to the car that will stop and surpass the requirement to stop per engine size and car. Hence the 139bhp 16v having 256 vented discs. There is no point in upgrading unless you are going to run a lot of power and require the stopping power.
Anyone on here with a driver will no doubt tell you the same.  :smiley:
Offline Neaty
Re: advice please
« Reply #4 on: 21 May 2006, 01:10 »
when i used to have a driver and rag the sh!t out of it i found the brakes were pretty good in comparison with the power it had stopped pretty well.
Slick what does IIRC mean?
as slick said they are 72 bhp, or 75PS depending on what way u look at it!  :nerd:
welcome to the forum by the way pitchy, u got alot planned for your driver?, any pics?
« Last Edit: 21 May 2006, 01:12 by Neaty »
  • Unit
Re: advice please
« Reply #5 on: 21 May 2006, 01:23 »
If I Remember Correctly  :wink:
Offline Neaty
Re: advice please
« Reply #6 on: 21 May 2006, 01:27 »
ah I c, thought it was some technical term!, drivers are on pierburg 2e2 carb arent they?
  • Unit
Re: advice please
« Reply #7 on: 21 May 2006, 01:32 »
Yeah but they still need an injection point of some sort, and i thought they were single point, not multi.  :undecided:
Offline steviem
Re: advice please
« Reply #8 on: 21 May 2006, 01:45 »
Being carburetted means its not injected...
although i have a feeling later drivers had spi??
Offline Mr Blue
Re: advice please
« Reply #9 on: 21 May 2006, 01:47 »
cant you fit vented disks off an 8v gti or are they all vented at the fronts?
I did this on my mk2 polo coupe  :smug:
« Last Edit: 21 May 2006, 01:50 by Mr Blue »
