Author Topic: HI HELP QUICK  (Read 1072 times)
Offline Lycara
  • Smoothed doors on a driver
HI HELP QUICK
« on: 20 May 2006, 14:35 »
Hi got another problem with the golf  :angry:. I got in it this moring an the whole of the driver foot well is soaked through. I was like wht the hell. It has been raining all last night never had the problem before wht cud it be?
minty freash driver,with smooth doors
Offline Bazzer
Re: HI HELP QUICK
« Reply #1 on: 20 May 2006, 14:40 »
check your doors, if they're soggy at the bottom it's the membrane, bit fiddly to fit a new one, but pretty straightforward.
If they're relatively dry, it's probably your bulkhead somewhere - mine leaked through the speedo cable grommet some numpty f*wit put a loom through when he 'fitted' the alarm.
To dry it properly though, you'll have to get the carpet out.  :sad:
Bazzer
Offline stan_deezy
Re: HI HELP QUICK
« Reply #2 on: 20 May 2006, 14:43 »
Bummer!
Check the door drain holes at the bottom: should be three. Get some stiff wire and give them a good poking!
Sunroof fitted? Open and check the drain tubes: again a long piece of wire.
Under the bonnet look under the plastic scuttle where the bonnet release cable runs: make sure it's tightly sealed: silicon it well.
While under the scuttle make sure the drain holes for the scuttle are clear of dead leaves etc etc
Check the smell from the floor: it isn't antifreeze from a leaking heater matrix is it?
Someone else will be along shortly with more suggestions too........
Offline Lycara
Re: HI HELP QUICK
« Reply #3 on: 20 May 2006, 15:26 »
Ty for all your replys it was one of the drain holes clocked up wiv sh**t dont think it ever been cleaned at all. It was comming from the clutcg cable where is was leaking. My bf dad took all the crap out and a load of water fell out of the drain hole so was propper cloged hopefully sorted. :smiley:
