Author Topic: How do I tell I have a Highline MFA?  (Read 8407 times)
Offline illyun
« on: 20 May 2006, 09:52 »
I ordered one but not sure if it is highline...   :undecided:
Mk1 GTI Campaign, Mk5 GTI Edition 30, Mk6 GTI (Coming Soon...)
Offline The Doc
  • E63s Estate - Vito Sport
Re: How do I tell I have a Highline MFA?
« Reply #1 on: 20 May 2006, 18:27 »
If is is HIGH it fills the whole area in the middle of the rev counter and speedo - see photo.
If its LOW it is split into 2 sections - top section is warning lights - lower is fuel comupter etc.
Offline illyun
« Reply #2 on: 20 May 2006, 22:35 »
Oh thanks for that.. looks like I have a highline then  :grin:
Offline apple_power
« Reply #3 on: 24 May 2006, 18:14 »
Quick newbie question can you use the high line computer? I have only ordered the standard paddle shift wheel that comes with the DSG gearbox.  So can I use the computer or is it wasted?  I am getting it by ordering sat nav.  Thanks in advance.
56 plate Golf GTi
steel grey
5 door
Automatic DSG
18" alloys
leather black
electronically folding windows
cruise control
multifunction steering wheel
xenon
and winter pack inc heated seat and washer jets
smoker pack
phone prep for nokia 6230i
sat nav dvd with full display
6 disc changer
ipod fit
rear parking sensors
Tinted windows
Mini cooper S and Range Rover sport on order for Jan 07
Offline The Doc
« Reply #4 on: 25 May 2006, 18:37 »
YES you can use the highline computer & BONUS  :smiley: your wheel will be multi function as it is standard with the DSG on the GTi / R32 now!
If your car is not a GTi or R32 then your controls will be on the end of the wiper stalk!
« Last Edit: 25 May 2006, 18:40 by The Doc »
Offline apple_power
« Reply #5 on: 25 May 2006, 22:18 »
Hi Doc,
Sorry to question you again.  I just wanted clarification, so the GTi you are saying comes standard with multifuncation steering wheel?  Cos in gthe broucher I cant find that, also on line it wont allow you to add a multifunction wheel to car.  But VW taxfree reckon I can pay for one.  I just wnated to make sure.  I have ordered a standrad Uk spec apart from my extras.
Cheers Doc.
56 plate Golf GTi
steel grey
5 door
Automatic DSG
18" alloys
leather black
cruise control
xenon
smoker pack
6 disc changer
ipod fit
Tinted windows
Offline Matt555
« Reply #6 on: 25 May 2006, 23:23 »
I think the GTi with DSG has mid-line set-up as standard.  The multi function high-line wheel was an additional option when i ordered my GTi but was standard on the R32 ordered with DSG.
I only wanted paddles and once I saw that as standard fit on the DSG equipped GTi I cancelled the high-line order...
hope this helps
matty
Offline apple_power
« Reply #7 on: 25 May 2006, 23:42 »
Cheers Matt,
I was under the impression that paddle shift comes standard with DSG, which is what I wanted and knew.  Thanks for agreeing.  The sat nav come with a highline computer, so no need to order one.
I did not order the multifunction wheel, as with the phone prep I can simply accept or end calls.  On my Merc command system I can make calls and dial numbers.  Also on my current cars, I can skip tracks, forward, rewind etc.  I was given the impression by the vw dealer, I test drove the car that this was not possable.
Can some one clarify this please.
56 plate Golf GTi
steel grey
5 door
Automatic DSG
18" alloys
leather black
cruise control
xenon
smoker pack
6 disc changer
ipod fit
Tinted windows
Offline The Doc
« Reply #8 on: 26 May 2006, 20:57 »
Nope the spec changed for 2006 so you should get the MF wheel with the DGS - I'm off to the dealers in the morning so I'll check it then.
The highline MFD is standard with the Sat nav.
With the MF wheel you can change track, volume, mute the radio and access the extra menus on the MFD easy!
hope this helps but I will double check the MF bit for you!
Offline apple_power
« Reply #9 on: 26 May 2006, 21:20 »
Cheers for that Doc,
I would appreacite that greatly.  Thanks very much again.
56 plate Golf GTi
steel grey
5 door
Automatic DSG
18" alloys
leather black
cruise control
xenon
smoker pack
6 disc changer
ipod fit
Tinted windows
