Author Topic: upgrading suspension  (Read 1323 times)
Offline GolfGL
« on: 19 May 2006, 23:11 »
Im going to be upgrading the suspension soon so wanted to know what you guys recommend within a £200-300(max) budget to get the 2.0 a bit lower with better handling. At the moment when the wind blows the car wobbles its that soft :grin:
Thanks
Adam
Audi TT 3.2 24v v6 2005 - The Sloth - Weekends
VW Golf 2.0 8v GTI 1996 - Lemonade II -Daily
MNR Vortx Yamaha R1 2009 - Track days
Sold Seat Leon Cupra R 225 -LM04 NDE "Lemonade"
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: upgrading suspension
« Reply #1 on: 20 May 2006, 11:45 »
Hi, Adam.  How are the wheels, looking?
First off, it'd probably be best to uprate the front & rear Anti-roll bars.  This will tighten things up nicely.
But if you need that lower look, then ring/email Awesome. They're very helpful, know what they talking about & are currently offering 15% discount to uk-mkiv members. (Don't know about members on here?).
If you do want to lower, then I'd only recommend lowering by about 30mm - Any lower, & the driveshafts might start rubbing. (Unless you uprate the ARB's, of course!)
Also, don't forget a geometry adjustment when you finished all the suspension.
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline GolfGL
« Reply #2 on: 20 May 2006, 22:43 »
The wheels are looking good il get some pictures up after the exams but theres such a difference in grip even though there only slightly wider and lower profile. I would go for uprated ARB's but im trying to save for the next project so at the moment just the essentials and it really needs lowering. How is the camber adjusted on the mk4 as il be doing it myself? what setups have other mk4 owners got?
cheers
