Golf mk2
Steering wheels
Topic: Steering wheels (Read 1016 times)
Haribo!
Steering wheels
19 May 2006, 17:47 »
ive got a 90 spec driver, and im getting a 90 spec GTI 16v, both on a H plate, but im not sure im gonna like the raid steering wheel im told it has and will most likely change it to the original, anyone know if my drivers steering wheel will fit?
Mk2Kezza
Here all the time
Re: Steering wheels
19 May 2006, 18:52 »
The spline size changed around about then, from small about 14mm to about 20mm. First thing, take your driver steering wheel off and have a look which size spline you have. The GTi should have the larger splin so if thats whats in your driver then it should be a straight swap.
<br />Almost finished.....
Haribo!
Re: Steering wheels
19 May 2006, 20:01 »
ah ok, i was aware of the different sizes but wasnt sure if they were model specific rather than year, cheers, sounds like it should work then
Golf mk2
Steering wheels
