Golf mk2
**Bottom ENd Knock**
Topic: **Bottom ENd Knock** (Read 2016 times)
golf gti 16valve
Here all the time
19 May 2006, 15:50 »
Hi ya ppl,basicly my bottom end is knocking,it only does it once its war, if you drive the car the oil pressure drops on it, could this be because of the oil jets on the conrod?? but basuicly i want to know wot i would have to do to get it running sweet again,ive heard you can just change the bottom shells,but that it will more than likely come back after 5k?is this correct, or will i have to replace top and bottom shells and get the crank all re-ground etc? how much would i be looking at do you think,
its beaking my heart at the momment coz ive just put a new head on it and on tick ova it runs like a brand new car, plz let me know, im curently driving a Pug 306 Diesel!! i need my golf
Gambit
Forum addict
Re: **Bottom ENd Knock**
19 May 2006, 16:09 »
you only need to get the crank reground if its been scoured.
if its knocking then you need to get it dismantled and see where its knocking
in short - its gonna need a bottom end rebuild
golf gti 16valve
Here all the time
19 May 2006, 16:26 »
ok then,how much roughly would a bottom end rebuild cost in parts, i get 10% on vw parts, and how many hours labour do you think?
systemseiko
Here all the time
19 May 2006, 20:25 »
Start with a set of Rings, Head gasket, sump set, Big end and crank bearings, crank seals, reconditioned oil pump with oil and filter, looking at about £150.00 parts and £250.00 labour conservatively.
If it is a 90 mph per hour wind and you drive your car at 90mph downwind, if you stick your head outside would you feel the wind?
carpetmonster
GTI forum regular
carpetmonster 16v keep it retro
20 May 2006, 21:24 »
you can always go for the cheap option saw dust,only kidding what about a replacement engine?may be cheaper.
Golf mk2
