Author Topic: gearbox oil  (Read 4774 times)
Offline Gambit
Re:gearbox oil
« Reply #10 on: 15 December 2003, 16:11 »
its the only 17mm hex bolt on the underside of the diff
an easier way to fill it is thru the speedo cable hole, with the filler bolt on the side removed, then when it seeps out the side of the filler hole you know its full
bit less messy but its 6 of one, half a dozen of the other really!
Offline Gozza
Re:gearbox oil
« Reply #11 on: 15 December 2003, 17:11 »
OK problem is I cant find the filler bolt, I have found the 17mm hex bolt which is the drain plug but am fcuked if I can find the filler. Haynes manual is not helpful either as does not show a pic of it. To make matter worse my car has been lowered 60 mm :(
golfvr6
Re:gearbox oil
« Reply #12 on: 15 December 2003, 19:04 »
Look behind the front/left wheel. It is at the end of the gearbox.
Offline Gambit
Re:gearbox oil
« Reply #13 on: 16 December 2003, 11:54 »
its probably covered in all the sh!te of the day!! so you may have to give it a bit of a clean to see it!
Offline Gozza
Re:gearbox oil
« Reply #14 on: 18 December 2003, 17:23 »
Good point, I will have another look when I can be fcuked. After xmas now me thinks :), too damn cold otherwise !!
golfvr6
Re:gearbox oil
« Reply #15 on: 18 December 2003, 17:26 »
The filler plug looks just like the drain plug.
Offline GTI NZ
Re:gearbox oil
« Reply #16 on: 21 December 2003, 10:06 »
have a real good look, it took me a while too find it as well
Offline Gozza
Re:gearbox oil
« Reply #17 on: 21 December 2003, 12:49 »
thx all, not got round to it yet as tried and it was bloody freezing. Problem I am having is the fact it is so damn low, I brush my cheek on the bumper trying to get my head under :(. Will report back once I have tackled it.
Thx again
golfvr6
Re:gearbox oil
« Reply #18 on: 21 December 2003, 22:33 »
Probably would be easier to jack up a little and turn the steering.
