Author Topic: water light flashes now and then  (Read 2679 times)
Offline BobbyT
« on: 17 May 2006, 18:24 »
hi, have just got my car back from the garage but for some reason the red light on the warter temp guage flashes now and then! anyone know what would cause this! its not over heating and the fan kicks in fine? cheers, rob
Re: water light flashes now and then
« Reply #1 on: 17 May 2006, 21:34 »
first thing to check is the water level is topped up.  If that checks out then the level sender may be about to pack in.  Bridge the pins on the plug, if this stops the flashing replace the sender, if it doesn't then you've got a wiring problem, or perhaps the dash temp sender is about to give up.  Its the black one with a brown & a red/yellow wire, located in the coolant flange at the front of the head.
Offline benmk1
« Reply #2 on: 18 May 2006, 08:53 »
you haven't had the water dropped/changed have you? Just thinking could be an air lock......just a thought
I don't look at porn much,
usually 2 or 3 minutes is enough
Offline BobbyT
« Reply #3 on: 18 May 2006, 17:56 »
had a new expansion bottle and sensor fitted, supose it could be an air lock! will see if i can sort it! :smiley:
Offline BobbyT
« Reply #4 on: 21 May 2006, 15:38 »
well i dont really know what the trouble is, now the guage goes right to the max level with the light flashing but as far as i know this cant be correct as the car is fine and the water level is ok and the fan works! maybe i should replace the sensor!  :undecided:
« Reply #5 on: 21 May 2006, 20:20 »
Thats the black temp sensor for the dash gauge, my mate had exactly the same problem :)
Offline BobbyT
« Reply #6 on: 22 May 2006, 11:13 »
so is it the sensor which fits in the bottle?  :smiley:
« Reply #7 on: 22 May 2006, 11:27 »
No sorry, the one in the top rad hose coolant flange on the front of the head  :)
Should have a 2 pin connector with a brown & red/yellow wire (or perhaps only a single red/yellow wire on a MK1 GTI?)
Offline eyeletboy
« Reply #8 on: 22 May 2006, 12:45 »
this is a long shot but i had this problem on my mk1 sportline.have you got braided hoses running over your rocker cover? if they are,move them so they are not making any contact with the rocker cover.this sorted my problem out.there was a short causing the temp gauge to flash and wander all over the place.
Offline BobbyT
« Reply #9 on: 22 May 2006, 13:05 »
i will take a look later on bro!  :smiley:
