Golf mk3
hardmonkeys
Ignition Coil replacement
Topic: Ignition Coil replacement (Read 1402 times)
craggers
17 May 2006, 14:01 »
it broke down last night !! A friendly RAC told me that it definately coil.
Just ordered Ignition Coil and is it easy job to replace or it a b!tch of job?
nosaj26
GTI forum regular
Re: Ignition Coil replacement
17 May 2006, 14:54 »
really easy -i managed!!!. when you get the coil it will be self explanatry on how to replace if not get out the trusty haines manual
james_biscuit
17 May 2006, 15:26 »
Easy as pie. We have had the ignition coil go on both our MK3's and replaced them ourselves.
monkeyalan
17 May 2006, 15:53 »
two bolts and an electrical connection - 5 mins max.
craggers
18 May 2006, 09:43 »
All,
Cheers - let hope it do the trick !! miss driving it and last 2 days I had to drive Wife's Vectra, it not the same !!!
Walkers Wagen
Dragon Green 8v 2.0 GTI
18 May 2006, 14:12 »
I found it easy as well, though I took of the plastic cover off that covers the pollen filter just removed the 5 or 6 plastic press studs then got to the 2 bolts that hold the coil on, sounds alot of work but it's not really 10 min job max
craggers
Reply #6 on:
18 May 2006, 14:58 »
Well it not 10 mins job now ... now it 2 days job as they gave me the wrong part !!! goddamit
Told them it AGG engine etc and still get wrong one !!
monkeyalan
Reply #7 on:
18 May 2006, 15:34 »
try it anyway.
craggers
Reply #8 on:
18 May 2006, 19:11 »
Now sorted
... made some modification to the fitting and the car work sweet now.
Been at it for 2 hours rather than 5 mins !!
Golf mk3
hardmonkeys
