Author Topic: HELP MARK3 GOLF  (Read 1408 times)
Offline NUG
HELP MARK3 GOLF
« on: 16 May 2006, 19:15 »
JUST GOT A GOLF GTI 8V 1995
.PROBLEM IS THE BRAKE PEDAL IS FIRM WHEN BRAKING THEN IT SIMPLY SINKS TO THE FLOOR LOOSING BRAKE POWER.IVE LOOKED BEHIND THE SPEEDO DISPLAY AND THERE IS NO ABS BULB AND A YELLOW WIRE HAS BEEN CUT,I HAVE ALSO NOTICED THAT IT DOES NOT HAVE ANY ABS SENSORS IS THIS RIGHT PLUS NO ENGINE MANAGEMENT LIGHT PLEASE HELP
Offline lch1
Re: HELP MARK3 GOLF
« Reply #1 on: 16 May 2006, 20:32 »
mate this could be one of many problems from a faulty master cylinder to air in system may i suggest that you have brakes properly inspected by someone who knows what they are doing as this is dangerous to drive as the most expected will happen there is no short answer unlees you know what you are looking for
regards
LCH1
Offline NUG
Re: HELP MARK3 GOLF
« Reply #2 on: 16 May 2006, 20:43 »
THANKS
IVE JUST BROUGHT THE CAR FOR MY WIFE AND ITS GOT 12MTS MOT ON IT. WOULD THIS FAIL.
Offline Len
Re: HELP MARK3 GOLF
« Reply #3 on: 16 May 2006, 20:50 »
Not sure if 8v got ABS.......
Anyway the symptoms you describe may not have shown up on the MOT, if it had it would have failed but..........
Were you there? Did you watch the test?
As said above that can be any fault, bleeding, master cylinder, servo, sticky caliper. Any or a combination so get it checked out at a reputable place.
www.sas.org.uk
www.the-ace.org.uk
Offline NUG
Re: HELP MARK3 GOLF
« Reply #4 on: 16 May 2006, 20:57 »
IVE BROUGHT THE CAR WITH 12MTS ON IT. ALSO IVE PULLED THE DASH OUT AND FOUND OUT THAT A YELLOW WIRE IN THE INGINTION HAS BEEN CUT. DO YOU KNOW WHAT THIS IS?
Offline NUG
Re: HELP MARK3 GOLF
« Reply #5 on: 16 May 2006, 20:59 »
SORRY I MEANT TO SAY IVE BLEED THE WHOLE SYSTEM AND CHECKED THE CALIPERS
Offline blue_concept
Re: HELP MARK3 GOLF
« Reply #6 on: 16 May 2006, 21:58 »
i had a similar problem with the lights
got it checked out at the vw garage and they said it was faulty sensors, got new sensors not cheap £60 each. after a few months the light still stayed can on again.
i recon the same happened to your and the person you purchased it from wanted to sell it without ppl asking questions about the light, i must admit i have been tempted to do the same on mine. best bet it to get it tested out but i recommend you avoid the stealership because they are pretty clueless.
am i right in saying it either a colour concept or an VR6?
Offline lch1
Re: HELP MARK3 GOLF
« Reply #7 on: 16 May 2006, 22:05 »
may i suggest you check cylinder again as mot is only valid on day of check and may have failed after this if you have bleed system recheck as air may still be in system as only couple of pushes on pedal may not have cleared this problem dont want ot teach you to such eggs but have you allowed for vacum when bleeding as on return of pedal you may have taken in air to system this does require two man method to lock of bleed valve as pedal is fully depresed
sorry if i am teaching you to suck eggs
regards
lch1
Offline NUG
Re: HELP MARK3 GOLF
« Reply #8 on: 17 May 2006, 20:17 »
THANKS FOR YOUR HELP IT IS THE MASTER CYLINDER THATS BUGGERED GETTING ONE FROM WILCO £82 AND IM GONNA DO IT MYSELF THEN GET SHOT OF IT
