Author Topic: fusebox cover removal  (Read 1018 times)
Offline simon99
« on: 16 May 2006, 13:13 »
silly question I know but how you you remove it as I think I have a faulty fuel pump relay. and what number is the relay.
Offline Greg
Re: fusebox cover removal
« Reply #1 on: 16 May 2006, 13:34 »
Just pull it harder :smiley:
Part number for ECU Relay - 165 906 381
think its got E30 written on it ? ?
'99 Mk4 1.8T - FMC007p - R-Tech Stage 1 | '97 Mk3 16v | '91 Mk2 16v | '83 Mk1 L
http://blackgolfgti.blogspot.com
Offline Dom Mk3
  • Insert wit here
« Reply #2 on: 16 May 2006, 13:35 »
have you pushed in the two green tabs? might need some gentle persuasion... gave mine a light thump!
Offline simon99
« Reply #3 on: 16 May 2006, 13:49 »
pushed the green tabs but nothing happened although did it quickly at work today. might take the whole thing apart tonight to see why its seems to be stuck. Knowing my luck I will probably break it if I try and pull the cover.
Thanks for the answers and hopefully it wont cut out too much on the way home.
Offline nosaj26
« Reply #4 on: 16 May 2006, 19:46 »
not the easiest to remove, press the green tabs and litetally rip it off!!!!!!!!!!!! try not to do any damage though
