Author Topic: Window rattle  (Read 1389 times)
Offline Gambit
Window rattle
« on: 16 May 2006, 09:16 »
when i have my window down a wee bit, say a inch or two, it rattles like fook when i go over bumps or something.
is there something im missing from the around the top of the window that keeps it tight int he channel and stops it rattling? it does my nut it!!
Offline Steve_B
Re: Window rattle
« Reply #1 on: 16 May 2006, 10:54 »
In a semi-hijack way, I've got a similar problem, if I close the door with the window down it sounds like the glass is going to smash. Not much help to Gambit but maybe it's the same thing?
Offline Gambit
Re: Window rattle
« Reply #2 on: 16 May 2006, 11:06 »
yes thats the same thing i have. basically the window aint a tight fit!
Offline Agreeable Slick
  • Unit
Re: Window rattle
« Reply #3 on: 16 May 2006, 11:09 »
Might be worth whipping the door card off and having a look behind the plastic sheet and see what the state of the support runner is and the guide runner going to the top of the window, it's possible that one end might have popped off and loosened the windows sitting position.
On another note, my drivers window just doesn't go back up when it's been put down, it just sits there farting at me.  :cry: :grin: Must fix that.
Judderi
Re: Window rattle
« Reply #4 on: 16 May 2006, 11:24 »
I think its the bit that runns along the bottom of the window on the inside and out that hold the glas tight. I seem to remember mine doing the same and after i pulled it off and re seated properly it was ok.
Offline Gambit
Re: Window rattle
« Reply #5 on: 16 May 2006, 12:11 »
o aye, they are metal them aint they so can be bent/tweaked to tighten the fit
Re: Window rattle
« Reply #6 on: 16 May 2006, 17:44 »
Slick: Replace the front window guide, mine was the same :)
