Hi
I have a split water hose on my mk3 gti 8v engine code AGG which I have bought the replacement for direct from vw as gsf said they didnt stock it. When I replace it I am assuming that I need to drain the coolant system first, replace the faulty hose and then refill the coolant with brand new stuff. Sounds easy!?! but I have a few questions before I try it
1) Whats the easiest way to drain the coolant system? (ie which hose do i need to pop off to drain it all, is it a good idea to jack the back of the car up so it drains easier etc)
2) What coolant should I buy to fill the system back up again and how much roughly will I need? (I have read that G12 pink coolant from vw dealer is best but is this suitable for my car and what kind of quantity am I going to need to fill the whole system back up)
3) When refilling do I need to make sure there is no air in the system or are there any things I should check once full to ensure that its been done correctly.
Any help appreciated
Thanks
Andrew
