Author Topic: ? Buggrd Box  (Read 1899 times)
Offline benmk1
? Buggrd Box
« on: 15 May 2006, 16:20 »
Just found this on underside of my gearbox (5 speed gti) :cry:
 is it cream crackered?
Can't find the bits that cracked off, why am I so clumsy :embarassed:
I don't look at porn much,
usually 2 or 3 minutes is enough
Offline richandhazel
Re: ? Buggrd Box
« Reply #1 on: 16 May 2006, 00:28 »
That looks like the bell housing and would that be one of the bolt holes for the small plate that fits at the bottom? If so, I wouldn't worry. Its held on with 3 bolts so one missing won't hurt.
Offline benmk1
Re: ? Buggrd Box
« Reply #2 on: 16 May 2006, 10:26 »
yea it's the bellhousing, just a thought I could remove the bellhousing off the old 'box and swap......I should think (after being told :rolleyes:)
Re: ? Buggrd Box
« Reply #3 on: 16 May 2006, 10:38 »
Any chance you could take a picture showing more of the box, with say an arrow pointing to the damaged thread? If its what I think it is then swapping bell housings is more work than its worth.
Re: ? Buggrd Box
« Reply #4 on: 16 May 2006, 10:40 »
Actually, if its easier, you could answer this question instead of taking a picture: Was the socket/spanner you used to remove that bolt 10 or 11mm?
Offline benmk1
Re: ? Buggrd Box
« Reply #5 on: 16 May 2006, 23:28 »
Can't remember now it was a few months ago :embarassed:, it's the one at the bottom!
Re: ? Buggrd Box
« Reply #6 on: 17 May 2006, 07:08 »
In that case, I'm sure its the middle bolt for the little dust plate at the bottom. The other 2 bolts will hold it fine. I've seen them before now with that plate completely missing so I wouldn't worry.
Re: ? Buggrd Box
« Reply #7 on: 17 May 2006, 12:52 »
I concur, the only bolt holes on the bottom of the bellhousing on that side will be fore the little cover plate, all the main gearbox mounting bolts go through holes in the gearbox casing into the block :)
Offline benmk1
Re: ? Buggrd Box
« Reply #8 on: 17 May 2006, 16:55 »
Cheers guys that's reassuring, I may just get a quote on having it welded though.....if I find the time
