Author Topic: Rear wiper???  (Read 1087 times)
Offline HuwMk2
Rear wiper???
« on: 15 May 2006, 12:46 »
My rear wiper works fine with the spray but otherwise when on sticks or goes slowly. Has anyone experiencd this? What's the problem?
Offline takethefifth
Re: Rear wiper???
« Reply #1 on: 15 May 2006, 12:51 »
Check your linkages in the boot, make sure the wires running to the motor are giving a true 12v as sometimes these wires get cracked, other than that sounds like a replacement motor is needed.
Re: Rear wiper???
« Reply #2 on: 15 May 2006, 17:16 »
Swap the relay if it sweeps fine when you wash the rear screen.  It's #19 on the fuse board and is same on pretty much all VWs & later SEATs :)
Offline HuwMk2
Re: Rear wiper???
« Reply #3 on: 15 May 2006, 20:09 »
Sorry, I don't understand what is meant by changing the 'relay' sorry. Teacher, no mechanic.
Offline Simpson
  • one day il learn
Re: Rear wiper???
« Reply #4 on: 15 May 2006, 20:36 »
if you look under the drivers side dask there is a fuse box open the lid and there are a load of fuses and square blocks (called relays) these are used to time the wiper on and off when you press the switch as above look for the one with 19 written on it then pull out carefully and replace.  :smiley:
i must buy a new car!
Re: Rear wiper???
« Reply #5 on: 16 May 2006, 17:26 »
whoops sorry, #19 is the front wiper relay!  The one you need to replace is #72  :embarassed:
Offline Simpson
  • one day il learn
Re: Rear wiper???
« Reply #6 on: 17 May 2006, 17:34 »
ah yes i found this out today myself sorry i was wrong too. 72 boy  :smiley:
