Author Topic: Mk2 1.3 Wiper switches ?  (Read 5466 times)
Offline Liam
  • Golf Mk3
« on: 16 April 2003, 04:10 »
Its bwggered, Went to try and change it and ended up knackering the indicator switch aswell  ::)
Anybody know how to fix it all ?? The indicator now flashes too quick and the wipers wont stop no matter what i do.
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Made In Germany Refined In Wales
Offline dubster
Re: Mk2 1.3 Wiper switches ?
« Reply #1 on: 16 April 2003, 22:14 »
its verry easy to change the indicator and wiper switches.
take off the steering wheel and you will find three little screws,unscrew them and the whole thing will come off.
search for a other one in the scarbyard,they are easy to find and not to expensive.
i had the same problem and it took me about 20 mins to change it.
good luck
p.s.  sorry for my bad englisch,but i am from belgium.
Offline Liam
  • Golf Mk3
« Reply #2 on: 17 April 2003, 03:57 »
i took the steering wheel off and the screws and i couldnt get to the switches.
Offline richandhazel
« Reply #3 on: 17 April 2003, 10:50 »
Once you take the steering wheel, shroud, 3 screws off and disconnect the electrics, the switches should slide off the steering column as a complete unit.......if memory serves me correct.
Offline Liam
  • Golf Mk3
« Reply #4 on: 18 April 2003, 04:23 »
nope, didnt work
« Reply #5 on: 18 April 2003, 14:25 »
I'll have a look, maybe I'm mixing it up with the Mk1, they might be different.
