Author Topic: help! she's been asleep 4 two years and she now needs new wheels  (Read 1471 times)
Offline mk1monkey
hello people,
Just to fill you in I bought a rust bucket 1982 2 years ago and I'm nearly finished so I have had 2 years of looking through mags and checking out websites trying to get ideas of what i'm going to do.
I thought I would start at the bottom with the wheels, i've got a few questions that hopefully you guys could help me.
Which other alloys could I fit on my mk1, for example could i stick a set of peugeot 205 or bmw 3 series?
Would any other vw alloys fit on there like mk3 gti alloys?
how much would I be looking at for a set of lower profile tyres to fit on a set of original 9 spoke alloys for a gti.
cheers people
Offline foxy mk1
the stud pattern u r looking 4, rover vaux bm
Offline mk1monkey
cheers foxy i don't think i will be checking out the rover alloys on the bay of plenty, maybe a early set of bmw wheels.
cheers
4 stud BMW e30 wheels fit perfectly, they often have a slightly lower offset of 24-25 so fill the arches nicely :)
Vauxhall have correct PCD but the centre bore is ever so slightly smaller, something like 0.5mm.  Someone on the forums fitted a set and all was peachy till he tried to get them off again, they were siezed solid!!
This will likely only be an isssue with OEM vaux wheels, most aftermarket alloys will have spiggot rings which you can either replace or open out slightly.
One thing to remember though, is to check the bolt seating before you fit them, most BMW/aftermarket wheels have a tapered seating whilst OEM VW are a ball seat.  Best way to tell is stuff a big lump of blue-tack into the bolt hole and check the shape.
If you need a tapered seating, BMW bolts are the correct thread pitch and will be tapered :)
