Author Topic: HOW TO TUNE PIERBURG 2E2 CARB. C.O.?  (Read 3509 times)
Offline faigolfgti
« on: 14 May 2006, 05:54 »
How to tune pierburg 2e2 co?Is it clock wise to tune rich or lean?Please advise!Thank You.
Offline jezza16v
Re: HOW TO TUNE PIERBURG 2E2 CARB. C.O.?
« Reply #1 on: 14 May 2006, 22:22 »
Hi, turning the screw in the top of the carb clockwise makes it weaker but this really only adjusts the 'idle' mixture. I would suggest you unscrew the idle jet fully first and take it out and clean it with petrol or carb cleaner. From memory it has a thin slit down one side and this often gets clogged up. As you screw it in the amount of the slot exposed gets less so less fuel can get through. You can't really adjust the full range mixture because the main jets are not adjustable.  :smiley:
Offline Agreeable Slick
  • Unit
« Reply #2 on: 15 May 2006, 01:42 »
or look in the maintenance and info section
Offline faigolfgti
« Reply #3 on: 15 May 2006, 06:18 »
More reply please!Thank You.
Offline takethefifth
« Reply #4 on: 15 May 2006, 12:46 »
As above.... There is a full write up there.
