Author Topic: Anyone interested on "HOW TO" Guides for Reverse park sensors & Car phone kits?  (Read 9159 times)
Offline The Doc
  • E63s Estate - Vito Sport
Take a look at these babys I fitted to my better halfs car.......
and here is the optional audio / visual display unit mounted in the headlining so you can see it in your rear view mirror - the numbers are reversed so you can see em the correct way in ya rear view mirror!
I think they are neater than my factory fit ones and were fitted by yours truly!  :wink:
« Last Edit: 25 May 2006, 19:10 by The Doc »
Offline Dom Mk3
  • Insert wit here
is that a parkitright kit?
Offline zeb
Excellent work Doc! Those little sensors are quite flush actually! I think it looks like the "Steelmate PTS" variety you have there?
Offline The Doc
Top points for Zeb! lol!
Steel mate are the kit to go for!
Offline davyk31
Looks great Doc, so what kind of a job was it to fit the kit?
Mk 7.5 GTi Indium Grey with 19" Brescias
Offline The Doc
It took about 1 hour to fit start to finish but I was in a hurry so couldn't take photos.........
On the next one I do I will take pictures and post them here with instructions!
In the mean teme I will take some pics of her car to give an rough guide!
Offline zeb
Hey Doc! On your recomendation, I picked up the same kit from Halfords for £200 which includes installation and have my fitting booked for 10 June. I noticed that you have your sensors on the bumper lower down.
I suggested to the fitter today whether he would put them there too and he said it is a bit too low and may not pick up higher obstacles so he's going to fix them up higher in line with the number plate, which means they will require colour coding too.
Any adverse effect of having your sensors down there?
Also, fitter said he may have to take the bumper off, did you have to do this?
Cheers!
Zeb
Offline The Doc
Hey Zeb
You wrote....
Thats great but I never recomended getting halfords fo fit anything....... the point of the guides is to help you guys fit your own gear instead of some no-brainer looser with a saxo 1.4!  :grin:
I noticed that you have your sensors on the bumper lower down. I suggested to the fitter today whether he would put them there too and he said it is a bit too low and may not pick up higher obstacles so he's going to fix them up higher in line with the number plate, which means they will require colour coding too.
Here we go.........  OK so what if their to hi and cant pick up stuff thats lower? Plus the snsors can be angled slightly upwards with the newest kits. The sensors work fine there and they perfectly match the black lower section of the bumper! Why paint them when you need to??????
Nope I normally fit these to vans - lots of them and there lower still!
Nope I left it in place and pulled the wires up by the removing the rear lights his can be done if you fit them on the upper or lower of the bumper.
At the end of the day the kits cost around £100 so why not DIY it my man? At the end of the day you will be far more carefull than any halfords fitter.....
Sorry if I sound negative but I dont want your car messing up - where do you live? If you want to come over I will fit them for you (FOC) and we can take photos of the fitting for the forum!
Doc
« Last Edit: 29 May 2006, 21:35 by The Doc »
Offline Dom Mk3
  • Insert wit here
does the golf have "super hard bastard" metal reinforcement bar behind the rear bumper ala touran? If so, for god's sake... go lower!!
Offline The Doc
ILMAO and there also on the caddy van as I just found out  :sad:
The things about 5mm thick ffs!  :angry:
I suppose thats what your paying for!  :smiley:
