Author Topic: how accurate is the computer?  (Read 2293 times)
Offline shiftyhowe
« on: 13 May 2006, 14:31 »
was playing with the computer thingy today and was wondering how accurate it was, a little suspicious at the mpg being at 36.3 although I aint be driving the car hard :rolleyes:, especially since the ford computer sucked big time in my orion and looked like it belonged in a taxi.
Offline rowlers
  • I'm back - MK7 GTI
Re: how accurate is the computer?
« Reply #1 on: 13 May 2006, 15:49 »
I'd guess not very, My mpg is 40!
Offline carpetmonster
  • carpetmonster 16v keep it retro
« Reply #2 on: 13 May 2006, 21:31 »
mine read's 35 to 36 on a 12 mile journey to work.motorway most of it though. :smiley:
Offline s3akr
  • Looking for my 2nd MK2 - 16 valves? Suits you sir!
« Reply #3 on: 14 May 2006, 10:30 »
I checked mine against the petrol pumps on a refill and it was only about 2mpg out. I get around 36mpg out of mine on the daily motorway commute @ 75 - 80 mph.
Current Cars : Leon FR TDi 150 (Revo'd), Pug 406 Hdi 90 (I'm not proud of it)!     Past Cars :- Mini 1000 (x3), Metro (GTi 16v, MG Turbo),  AX GT (x2), Cavalier (1.3, Sri, GSi2000), XR2 (Mk II), R5 GT Turbo (Phase 1, 2xPhase 2),XR3i Cab (x2), Pug 206, Golf (1.8 GLi Cab, V5,1991 MK2 GTi 8 Valve), Accord Type R, MX-5 (phase 2), BMW 3 Series (E30 320i Cab, E36 318iS Coupe, E36 M3 Coupe), Clio (16v, Williams 2), Audi S3(Revo'd)
Offline gillo_grumlin
« Reply #4 on: 15 May 2006, 10:26 »
The computer will alway be abit out as it a calculation based on feedback from sensors which are calibrated to a specific or range of values/settings.
So for example you have 15", 16", 17" rims those calculations will be silghty out due to the 1%-7% difference in speed using different tyre. Also using stock rims and tyres, as these wear slightly will give a % of error of around 1%.
The vacum sensor on the back of the dash clocks is probably the most important component of these calculations, so if you start seeing high mpg check for very slight slight vacum leeks or try a different sensor. As this would indicate a slight fault in that locale, also a good check is check all earth cons are in clean and connected correctly.
« Reply #5 on: 15 May 2006, 10:27 »
for earth read GND/ground
