Author Topic: Brakes!!! leaking mk3 gti  (Read 1059 times)
Offline vinny_coupe1979
« on: 10 May 2006, 09:44 »
Ok underneath on passenger side neat the back under the car is where the brake pipes ( 4 i think) go into a box of some sort and then onto the rear wheels, i seem to have fluid leaking from this? what is it called and anyone know how easy to change how much etc?
Re: Brakes!!! leaking mk3 gti
« Reply #1 on: 10 May 2006, 09:47 »
would it be brake pressure regulator??
Offline Bazzer
« Reply #2 on: 10 May 2006, 09:51 »
Yeah what he said... I changed mine on the mk2 I had, and I thought it was pretty straightforward. But remember you will need to bleed your brakes afterwards - front and rear....
Bazzer
« Reply #3 on: 10 May 2006, 10:12 »
thanks!! was part expensive??
Offline Bazzer
« Reply #4 on: 10 May 2006, 10:15 »
£30 IIRC, but that was a couple of years back....
Bazzer
Offline AudiA8Quattro
« Reply #5 on: 10 May 2006, 13:16 »
Brake pressure regulator isn't always straightfoward, depends what model is fitted.
On some mk3's the regulator is mounted to the car with recessed allen key bolts, these don't come out very easily, and its very hard to get anything in there to remove them.
