Author Topic: 8V 2.0 GTi Cam belt Failure  (Read 1747 times)
Offline pcpaul
« on: 09 May 2006, 21:16 »
Hi Everyone,
First, what a great forum this is.  :smiley:
I have recently bought a 1992 8V GTi very cheap, as a project to do up.
Apparently the cam belt failed when idling. The previous owner had the belt replaced and the engine seems OK but is leaking water from the water pump so cannot drive far to test fully. I will be replacing this at the weekend.
The question is does this engine suffer valve damage or is it like the old Vauxhall 8V which is ok.
Many Thanks
Paul
Offline KINGS>
  • Watch out for the guns.....
Re: 8V 2.0 GTi Cam belt Failure
« Reply #1 on: 09 May 2006, 21:22 »
if its a pb engine code the valves never touch.... (apparently)
Offline pcpaul
« Reply #2 on: 09 May 2006, 21:29 »
Hi Big Guns!,
Thanks for the reply. Sorry to sound stupid but is the engine code the engine number?
Thanks Again
Paul
Offline AudiA8Quattro
« Reply #3 on: 09 May 2006, 21:51 »
PB is the 1.8 mk2 engine.
Can't say if damage will occur, why not do a compression test? that should tell you for sure without opening it up!
Offline pcpaul
« Reply #4 on: 09 May 2006, 22:23 »
Hi Volkswagenpolo2,
Thanks for the advice. I will try it this weekend.
Best Wishes
Paul
Offline stevo
« Reply #5 on: 11 May 2006, 16:54 »
Not VW specific, but If the water pump is driven by the cambelt , the re-tension of the new belt sometimes can knacker bearings/seals of the original water pump.
a Compression Test as previously stated is the first thing i'd look at.
« Last Edit: 11 May 2006, 16:57 by stevo »
Offline pcpaul
« Reply #6 on: 14 May 2006, 11:13 »
Hi Everyone,
Had the engine checked over this weekend and apart from the ignition timing being quite far out all seems well.
Thanks again
Paul
Offline GTI EDITION (aka LTD)
« Reply #7 on: 18 May 2006, 21:08 »
The engine code for a 92 2.0L 8v gti is most likely to be ' 2E '  :nerd:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
