Author Topic: Another DV question!!  (Read 1385 times)
Say bye bye
« on: 09 May 2006, 17:58 »
Ive got the forge DV fitted just wanted to ask you guys who have the same, do you find the thin pipe at the top is a little stretched??? Do i nned to replace the hose with a samco type one or something?????
Offline topher
  • Administrator
  • fully functioning
Re: Another DV question!!
« Reply #1 on: 09 May 2006, 18:35 »
yeah it is stretched. i think samco do a replacement but the stock one is fine as long as it hasnt cracked.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #2 on: 09 May 2006, 18:45 »
Yep, it's a tighter fit.  My stock one was a bit old & brittle, & kept splitting when I tried to force it on.  I gave Forge a ring, & they very kindly sent me a length of slicon to use instead. :smiley:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline cheekyboy_123
« Reply #3 on: 10 May 2006, 11:48 »
Had the same problem with mine...
2 hoses (bottom and side) came out eventually. Clips holding them in place were a bugger to get off.
The top hose came off easily but would go back in as it had become brittle...If you can't or don't want to wait for a replacement hose, just goto a decent cat spares shop like german and swedish where you can pick up some new hose and clips..
Add a bit a soapy water and it should just slide in...Don't overdo the water though..
Say bye bye
« Reply #4 on: 10 May 2006, 12:26 »
I got it on, eventually!!! just wondered if it was ok with a stretch.... prob will need somthing silicon though, seems a very light crack here n there.. cheers for the help lads!!
