Golf mk3
hardmonkeys
ABS. Removal of bulb panel without damage?
Topic: ABS. Removal of bulb panel without damage? (Read 1124 times)
STOMMO
09 May 2006, 16:55 »
Hi
How do I remove the panel that the ABS bulb is behind on my 97 GTI without any damage to the surrounding area. The ABS light is not coming on at all and has been no problem in the past, I'm assuming that the bulb has blown. I HOPE!!!
monkeyalan
Re: ABS. Removal of bulb panel without damage?
09 May 2006, 17:37 »
just prise it out genlty.
STOMMO
09 May 2006, 17:56 »
Cheers,Monkeyalan. Will do it now.
STOMMO
09 May 2006, 18:15 »
Hi
Fine. Ive got it out and the bulb is black so it looks like its bust. It looks to me like I need a new circuit board with both ABS and airbag bulbs. Is this correct and how much am I looking at from main steelers or is there somewhere on line that can do the trick for me?
Last Edit: 09 May 2006, 18:17 by STOMMO
adyh
10 May 2006, 09:37 »
I thought you could change the bulbs ?
monkeyalan
10 May 2006, 12:46 »
I don't think you can. I had to cover mine up for the MOT ( don't ask) cos i didn't think it would come out without causing damage.
STOMMO
Reply #6 on:
10 May 2006, 17:32 »
You can,t replace bulbs ,they are soldered onto board( unless youre a wizard with a pin size soldering iron) Ive managed to source a unit off of E.Bay. I dont know what we would do without good ole E.Bay. Rejoice!!!
Golf mk3
hardmonkeys
