Author Topic: Fault code 17676 (P1264)!!?  (Read 9477 times)
Offline dragongreen16v
« on: 09 May 2006, 13:45 »
Hi guys, got rid of my Mk3 16v and got a 115 GTTDi. Warning light came on so I got the laptop on the case. The fault code that came up was: 17672 (P1264). I rang VW, no help whatsoever. The car is running fine, but if anyone knows what it means that would be a great help!
Thanks in advance
Offline richandhazel
Re: Fault code 17676 (P1264)!!?
« Reply #1 on: 09 May 2006, 16:41 »
Looks like it is somewhere around here:-
http://www.golfgtiforum.co.uk/index.php?topic=35118.msg287977#msg287977
So either a coolant problem or fuel inj/air :undecided:
I reckon coolant.
« Reply #2 on: 15 May 2006, 20:36 »
Where would you find what the fault code means? The car has developed another fault pretty similar to the last one: 17675 (P1267) on cylinder 4!! I've tried Bentley's and VW. It's as if it has developed a unique fault because it's a special car. My luck.
Anywhere else I can check the full code listing?
Or shall I just wait til it dies?
« Reply #3 on: 15 May 2006, 21:19 »
I would have thought the Bentley was the best place. If its not in there I'm at a loss
Offline adrian mick
« Reply #4 on: 24 June 2006, 18:01 »
the 17675 is injector 3-control limit exceeded.        probable cause control period to long,wiring ,injector
the 17676 is injector 3-control limit not reached.      probable cause control period too short,fuel level low,air in fuel system.
  i got these fault codes from an auto-data diagnostic trouble codes book.
hope this helps ya out good luck.
