Author Topic: Anyone know about the mk1 GLI cab  (Read 3223 times)
Offline Lycara
  • Smoothed doors on a driver
« on: 08 May 2006, 22:34 »
I am thinkin of buyin one pro and cons of one? Any info rly wud help.
Thanx
minty freash driver,with smooth doors
Offline [han]
  • Graphic Designer for Haribo
Re: Anyone know about the mk1 GLI cab
« Reply #1 on: 09 May 2006, 07:44 »
have you seen insurance darl? lol almost as much as a GTI!!
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« Reply #2 on: 09 May 2006, 08:16 »
The Gli cab is the early GTI version - great car - make sure you check the following details on cabs...
http://www.vwgolfmk1.info/main/Buyingacab.pdf
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline Lycara
« Reply #3 on: 09 May 2006, 16:32 »
koool i rly want one can get insured on one for about 800 quid which aint bad for a run in the sun car. Anyone kno where i can get one?
Offline Madone_si
« Reply #4 on: 09 May 2006, 16:49 »
check out ebay, autotrader, all the VW forums - Golf+ mag, PVW mag....
SOLD - BLACK SOY 92
tomo320
« Reply #5 on: 10 May 2006, 00:02 »
why a gli mate? wierd question but they r one of rarest and not as much clout as gti but same insurance :huh: you have seen one cheap aint ya :wink: if theres owt specific you need to know let us know,
cheers,
paul
Offline Madone_si
« Reply #6 on: 10 May 2006, 11:22 »
cheers,
paul
Here is one on feebay - Item number: 4636417480
As for your comment regarding GLI not as much clout as GTI - I have one of each of these cabs and the GLI (1.8 version) is faster then the 1.8 GTI (due to better manifold and downpipe set-up) and has as much spec as the GTI - less power hood and windows, but these options are only on a few GTI's and not all of them from production...
All comes down to personal view regarding the GLi, GTI, Sportline, etc models of cabs...
For a real cheap cab you really want a 1.5GL but they are really rare these days.... - these where carb version as well.
More info on cabs... http://www.cabbyinfo.com/
« Last Edit: 10 May 2006, 11:33 by Madone_si »
SOLD - BLACK SOY 92
tomo320
« Reply #7 on: 11 May 2006, 00:17 »
ahhh i see, which manifold and down-pipe set-up is this then?
Offline Madone_si
« Reply #8 on: 11 May 2006, 00:36 »
four to two manifold - which is commonly known on the 82/83 mk1 GTI's have (6 bolts) with twin down pipes. The GLi is the early version of the GTI mk1's engines - later cabs GTI's have the crappie 4 to one with c clips...! I have no idea why they did this as the C clip 4 to 1 manifold leaks from the ring area - known issue with that manifold and C clips seem to give way after 18 months... I've just changed my GTI too the 6 bolt it makes a difference, plus easier to get off when wanting to work on the car.
SOLD - BLACK SOY 92
Offline mexicorich
« Reply #9 on: 12 August 2006, 19:40 »
How is vibration dealt with on the rigid 6 bolt manifold?
Is there some sort of flexi pipe between the downpipes and the exhaust?
