Author Topic: Wiring up mk3 clocks to a mk2  (Read 6103 times)
Offline Dizzie
  • Make friends with your fast
« on: 04 December 2003, 12:42 »
does anyone know how to do this? There is only 1 plug on the mk3 dials whereas the mk2 had 2 plugs, a vacume and the speedo cable. I know you need a Sensor added to convert the one to the other, but I've got no idea where to go from there.
Offline Gozza
Re:Wiring up mk3 clocks to a mk2
« Reply #1 on: 04 December 2003, 13:01 »
Haven't got a scooby, bet you though there was a constructive comment on here for a sec didn't ya  ;D ;D
Offline Gambit
« Reply #2 on: 04 December 2003, 13:09 »
you'll get an answer of here
http://www.golfgtiforum.co.uk/index.php
is's your the late spec or early spec loom? hazard light is on the steering column shrould in the late loom
Offline Dizzie
« Reply #3 on: 04 December 2003, 13:49 »
early, but converting your hazard to the '90 spec place is easy and the least of my worries.
all the bloody wires on the clocks loom from the mk3 are white  >:(
Offline Helios_Blue_Valver
« Reply #4 on: 06 December 2003, 15:52 »
Mate what i would do is sit down at the table with the schematics for a mk2 and a mk3 and a pad of paper. start figuring out what wire does what on each harness and where it needs to connect to a mk3. I may be able to sort some of it as I am pretty good with schematics but I don't have them for the MK3. If someone has a set of mk3 schematics they can email me I'll sit down tonight after the kids go to sleep and see what I can do. :)
Offline Dizzie
« Reply #5 on: 06 December 2003, 23:41 »
I got the wiring diagrams for the mk3 off the net. I think I've worked out what all the pins do on the mk3 clocks and got the indicators, high-beam and lcd lights to work. can't get the gauges to max out though.
I have no idea what to hook them up on the mk2 loom.
http://www.dizzie.biz/misc/golf3_94.pdf for the mk3's diagrams.
cheers for any help :)
« Last Edit: 07 December 2003, 09:54 by Dizzie »
« Reply #6 on: 07 December 2003, 01:27 »
won't come up for me mate. :)
Offline Dizzie
« Reply #7 on: 07 December 2003, 09:54 »
soz, editted the link now. u need acrobat reader too.
Blue MK2
« Reply #8 on: 07 December 2003, 23:53 »
Dizzy how much did you nab a mk3 dash for again? what should i expect to pay?
Im really looking to put one in mine. the corrado dash looks abit hard to install and dated
Offline Dizzie
« Reply #9 on: 08 December 2003, 13:19 »
?45. I can get you one if you want. it's missing a couple of bits though. If you want I'll ask and go pull it out for you.
