Author Topic: need to do a bit of filling  (Read 3041 times)
VeeDubGTI16v
« on: 08 May 2006, 18:18 »
im half way through doing a flushed plinth tailgate and now need to fill it ready for paint.
Can anyone gve me a bit of guidance, like what filler/fillers should be used. The only experience ive had is with p38 from halfords which cracked on me :huh: im getting it painted professionally so should i leave a layer of filler for the bodyshop to do?
cheers
Offline Uruk Hai
Re: need to do a bit of filling
« Reply #1 on: 08 May 2006, 18:41 »
It mite be worth seeing if you can get a plate welded in that isn't quite flush with the panel and then skim over the top with filler otherwise your going to have a fair bit of filler in there come the end and it could sink or crack
VeeDubGTI16v
« Reply #2 on: 08 May 2006, 18:45 »
done that already, the panel i welded in is pretty much level with the tailgate now, barely any filler will be needed :smiley:
Offline Uruk Hai
« Reply #3 on: 08 May 2006, 18:52 »
Go to a propper shop that supply's the trade with paint and filler e.c.t, they'll have better stuff than you get in Halfrauds and they'll probably be able to advise you the best product and method of using it  :smiley:
VeeDubGTI16v
« Reply #4 on: 08 May 2006, 20:00 »
ive got no idea where one of these shops would be, wouldn have thought the trade would go to shops, just remembered what hardcore said a while back actually :laugh:
http://www.autopaintinternational.com/products.html
lightweight easysand filler or Tetrosyl Ultra filler :huh:
Offline HARDCOR3
« Reply #5 on: 09 May 2006, 20:39 »
first of all give it a skim of fibreglass, this stuff is the best,
you should be able to get it at motorworld, or local motorspares, then after almost sanding it off, gove it a skim of filler, isopon p45 easy sand is available from car spares again, and is ok stuff, then it's a case of high build primer and keep wet flatting it back with some 800grit, if it was bodyshop, it'd just get a coat of stuff called "dolphin glaze", it's like a liquid flexible super fine filler that finishes smooth enough to paint over, top stuff, but doubt you'll be able to get it, unless thru a bodyshop... :wink:
VeeDubGTI16v
« Reply #6 on: 09 May 2006, 20:48 »
cheers hardcore :smiley:  sweet i can get high on fibreglass fumes again :evil:
Offline HARDCOR3
« Reply #7 on: 09 May 2006, 21:14 »
just remember to recomend "The Dub Factory" for all your bodywork needs....
 :embarassed: yeah i know it was a shameless plug....... :huh:
