Author Topic: suspension subframe  (Read 6174 times)
Offline Gambit
Re:suspension subframe
« Reply #10 on: 15 December 2003, 10:10 »
it aint that either, all wheels are straight & true.
as i said - it comes and goes, and when it does appear, it only vibrates when the engine is under load!
bizarre, nowt quite sure what it is!
« Last Edit: 15 December 2003, 10:11 by Gambit »
Blue MK2
« Reply #11 on: 15 December 2003, 10:31 »
engine/gearbox mounts vibrating the crap out of the car?
worn bushes/joints no?
that is scary stuff :o
Offline Gambit
« Reply #12 on: 15 December 2003, 10:41 »
nope, its only started happening since the new rack went in, so its something to do with that - we just cant locate it!
golfvr6
« Reply #13 on: 15 December 2003, 10:58 »
Have all the subframe bolts been checked for tightness?
Offline Gambit
« Reply #14 on: 15 December 2003, 11:04 »
yep, its only after getting the captive nut on the driverside re-welded
thought this was the problem to begin with but the vibration is still there
Offline Rexy
  • Backyard Racing
« Reply #15 on: 16 December 2003, 23:07 »
My Mk2's doing that as well :S Scary stuff i put it down to the front wheels being out of balance/track :S
I'll get it checked out after xmas is over :)
Blue MK2
« Reply #16 on: 18 December 2003, 19:49 »
its wear the wishbone rears bolts into.
just on this subframe problem, i've done a bit more research into it, mainly on clubgti and it turns out this is a common problem on mk2's.
ill give you some more info on monday when i get the car back. ive got a feeling this is what has been causing my knocking noise in the front of the car which i orginally thought was engine mounts
Gambit was the nocking noise like some sort of rattling noise because ive got a rattling noise and its made me think? :o
Offline Gambit
« Reply #17 on: 19 December 2003, 09:56 »
nah it was a noise u get coming on & off the gas, just like a thump
same sound u get with a knakered engine mount
Blue MK2
« Reply #18 on: 19 December 2003, 14:22 »
ohh right.
i think i know what you mean now Gambit. Engine mounts on mine need changing then :-\
Offline Bdub
« Reply #19 on: 19 December 2003, 15:09 »
I'm worried about this now since mine has done fumfty million miles!
has anyone got a picture of what we are talking about and where the problem occurs so I can check mine?
