Author Topic: Alloy wheel fitment.....  (Read 1471 times)
Offline dan7
  • 85 T25 camper, 90 Mk2 16v, 90 Caddy
« on: 07 May 2006, 12:20 »
Been offered a set of 16 inch Speedline Alessio alloy wheels off a mate. theyre actually off a ...wait for it- a nova! Anyway, they are four stud. The offset is 49mm. Has anyone ever seen these wheels on a mk3 golf? I know the stud pattern is the same, just wondering if theyd look a bit silly because of the offset, etc? My golf hasnt got the arch trims on it.  :huh:
Offline wag,en,volks
  • I make wheels shiney ,pm for quotes
Re: Alloy wheel fitment.....
« Reply #1 on: 07 May 2006, 23:57 »
you would need spacers or they would sit to far in the body,
+ spigot rings to alter the centre bore,
Offline dan7
« Reply #2 on: 08 May 2006, 17:08 »
thanks. where can i get the stuff youre on about? :huh:
« Reply #3 on: 08 May 2006, 18:51 »
you can try your luck on the internet ,
 or if your in no hurry then once the dubfactory is running at full speed we should be able to provide everything you need :smiley:
