Author Topic: Grrr split cv gaiter  (Read 2343 times)
Offline tobz.
« on: 04 May 2006, 17:10 »
Was standing outside having a ciggie a while ago and noticed a load of black stuff on one of my rims, I thought it was tar as I had to drive along a newly resurfaced road this morning  :angry:
On closer inspection one of my cv gaiters has emptied its contents all over my shiny wheel  :sad:
Am I right in thinking it should only take about 1hour at a garage to fit a new one???
You got any pics of your dad's split ?
Offline Agreeable Slick
  • Unit
Re: Grrr split cv gaiter
« Reply #1 on: 04 May 2006, 18:02 »
Do it yerself, it's a easy job to do.
Offline DavidGTi
  • The man. The legend.
« Reply #2 on: 04 May 2006, 18:22 »
I doubt it would take a garage that long to be honest, I certainly wouldn't pay for than the average 1 hour labour for it (£30-35), you may even get a decent garage that charges you half-an-hours labour, although most won't do this.
Its a fairly easy job, but when mine went last year I got a mate to help me, its just messy and arsing about.
"The distance between insanity and genius is measured only by success" - Carver, E
Offline tobz.
« Reply #3 on: 05 May 2006, 10:11 »
Would do normally slick but
a) I'm already fitting new discs/pads/bearings on my van this weekend
b) I don't think I've got a socket large enough for the hub nut
and
c) I got covered in cr@p just looking round the back there last night to verify it had split and not just popped off!!!
One thing I would like to know though for future reference, how is the CV joint held onto the end of the shaft??? Is it just a circlip that is blatantly obvious once you have cleared all the grease out of the way???
Judderi
« Reply #4 on: 05 May 2006, 10:42 »
Its some kind of pressure fit. You just belt it with a hammer to get it off.
Veedubgt18v
« Reply #5 on: 05 May 2006, 10:46 »
precise careful mechanical surgery then..........
Judderi
« Reply #6 on: 05 May 2006, 10:50 »
Yup. You gotta use the special tool. i.e the biggest hammer you have.
Offline AudiA8Quattro
« Reply #7 on: 06 May 2006, 23:36 »
The joint is held on with a circlip. Its a relatively easy job for someone that is experienced. For a newbie not that easy.
Offline shaft69
« Reply #8 on: 07 May 2006, 11:32 »
You can get stretch boots now so you dont have to split cv from shaft. Turn it inside out and stretch over. Only seen them the other day lads use them on the jobs say there brilliant. Saves all the messing trying to split the joint.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline tobz.
« Reply #9 on: 16 May 2006, 12:52 »
I thought I should just revive this thread as a word of warning to others not to use cheap CV gaiters!!!
My car is back in the garage today for its THIRD new gaiter!!!
When I got home after having the first done I noticed grease in the wheel again, jacked it up had a look and the was an abrasion and a split in it. The mechanic was very apologetic as we assumed he had trapped it with a spanner and he fitted another free of charge.
This was fine for a couple of days, then friday while cleaning the car I noticed the wheel was full of grease again  :angry:
Took the wheel off and this time the gaiter was covered in abrasions with about 3 splits in it! There was no way the guy was this careless. Thinking about my driving pattern last week the failures coincided with me putting my foot down on the way home on a private road to about 120 or so. We therefore concluded that the gaiter wasn't up to the job and had to be expanding at high speed and catching the bottom of the shock or the bottom ball joint bolts, there is absolutely no other way it could come into contact with anything.
Today it's back in the garage to have a genuine VAG gaiter fitted and hopefully this will end my saga!!!
So beware all there are some cheap gaiters for sale out there that aren't up to the job on valvers (I should ask tonight what the brand was).
Toby
